I’d like to know if there’s a way to do this too.
I’m about to install some sonoff duals which I will wire to light switches - plan is to send a toggle command to Home Assistant to turn my Yeelights on/off. Trouble is, if HA or the network goes down, I could be in a position that I’m flicking switches and I’m stuck in the dark without a fallover option.
Have a look at this as a possible solution:
Perhaps for basic functions, you could have it so that a quick double toggle reverts back to the ESPHome api onboard if HA can’t be contacted.
