ESPhome, Sonoff and external switches
Hello @efleming, how are you?
I have many sonoffs basics running EspHome with external switches. I’ve used GPIO14, TX and TX to attach three different physical switches with single, double, triple, quadruple, many and long presses modes, so I can use them with automations do do whatever you want with those click types. If you use it with three switches, you will have 17 possible functions, excluding the first switch, single press that is attached to the main relay. There is also a text sensor to publish the last switch number and click type so it can be used as automation triggers.
Here is the code I’ve created:
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: ${wifi_ssid}
  password: ${wifi_psw}
  fast_connect: false
  ap:
    ssid: ${friendly_name}
    password: ${ap_psw}
logger:
web_server:
api:
  password: ${api_psw}
ota:
binary_sensor:
## Buton 01
  - platform: gpio
    pin:
      number: GPIO14
      mode: INPUT_PULLUP
      inverted: True
    filters:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_multi_click:
      - timing:
          - ON for at most 1s
          - OFF for at least 400ms
        then:
          - light.toggle: main_light
      - timing:
          - ON for at most 1s
          - OFF for at most 399ms
          - ON for at most 1s
        then:
          - text_sensor.template.publish:
              state: "button_pressed"
          - delay: 50ms
              state: "button_01_double"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_01_triple"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_01_quadruple"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_01_many"
      - timing:
          - ON for at least 2s
        then:
          - delay: 50ms
              state: "button_01_long"
## Buton 02
  - platform: gpio
    pin:
      number: GPIO1
      mode: INPUT_PULLUP
      inverted: True
    filters:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_multi_click:
      - timing:
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_02_single"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_02_double"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_02_triple"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_02_quadruple"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_02_many"
      - timing:
        then:
          - delay: 50ms
              state: "button_02_long"
## Buton 03
  - platform: gpio
    pin:
      number: GPIO3
      mode: INPUT_PULLUP
      inverted: True
    filters:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_multi_click:
      - timing:
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_03_single"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_03_double"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_03_triple"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_03_quadruple"
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
        then:
          - delay: 50ms
              state: "button_03_many"
      - timing:
        then:
          - delay: 50ms
              state: "button_03_long"
output:
  - platform: gpio
    pin: GPIO12
light:
  - platform: binary
    output: main_relay
  - platform: wifi_signal
    update_interval: 60s
    name: ${friendly_name} - Wifi signal
    unit_of_measurement: '%'
    accuracy_decimals: 0
    icon: "mdi:wifi"
    lambda: |-
        if (id(wifi).state < -92.0)
          return 100.0;
        if (id(wifi).state > -21.0)
          return 1.0;
        else
          return round(( -0.0154 * id(wifi).state * id(wifi).state ) - ( 0.3794 * id(wifi).state ) + 98.182 );
text_sensor:
    name: ${friendly_name} - Switches
    icon: "mdi:light-switch"
status_led:
  pin:
    number: GPIO13
    inverted: true
There is also a nice formula to calculate the current wifi signal quality using percentage.
Hope it helps!
