Make HA assist smartwatch use openai
So i managed to get openai to work with my Android app assistant, but, my smartwatch ha assistant still is using the built in one.
Is there a way to force the smartwatch to use openai? Its set as preferred and is working in the Android app.
did you see this one?
I had not,i will try it and report back! Thanks!
So for anyone not wanting to repeat my mistake.
Wear OS 4 HA assist app.
You have to manually switch which voice assistant you use on the WATCH as well since its not controlled by the Android app. Open the ha-assist, tap on the grey text above the prompts. This will open a menu to choose your voice assistant.
