Make Home Assistant act as a general matter proxy for other protocols
The communication between Amazon Echo and Home Assistant still isn’t straight forward. You have to connect via the cloud. I guess this is similar for other voice assistants. On the other end, the current devices don’t implement the matter protocol. A protocol translating device would prepare them for the future.
Matter is designed for vendor independent communication. Please provide a matter API to Home Assistant, so that Home Assistant can act as a general proxy for devices connected by other protocols.
Virtual devices should also be exported by the matter protocol, that observes like Echo can directly react to changes in this virtual devices. The virtual devices can be orchestrated by HA automations and external observes can react to them.
I don’t know the specification of matter, to estimate it’s limitations, though. A hardware controller is maybe required to send this API, if matter doesn’t simply work over wi-fi, too.
Hope the idea gets clear enough.
It’s being under development…
It would be nice to select a random device (e.g. a Zigbee lamp) and export it as a Matter device to other controllers out there.
I’d really like such a feature. Is there now anything available like this?
Third Reality has something called Smart Bridge MZI – “Zigbee to Matter connectivity. Compatible with Google Home, Apple Home, SmartThings, HOME ASSISTANT, etc.” Not sure if it’s just their Zigbee devices, or anybody’s.
Other vendors have similar, e.g. Aqara M3 Hub.
I see Silicon Labs (“silabs”, who makes many of the IOT protocol communications chips) has “Unify Matter Bridge” software development kit, that runs on R-Pi-4, and appears to bridge both Zigbee and Z-Wave to Matter; sounds interesting.
And I see that Espressif (who makes ESP32 chips) has Zigbee to Matter bridge solutions. Including one that has two 2 ESP32 chips, one to handle Zigbee & one for Matter.
This is also asked here, and a way to do so can also be found there:
As a workaround, the Matterbridge add-on, does what you are after. It only supports a subset of device types at the moment, but it is being developed rapidly.
