Make it so Assist is available to select as Program to Launch
On android you can choose any app to launch on a double press of the power key. Currently you can select the Home Assistant app but not the Assist part that will launch from the home key long press. It would be much better if the assist function could launch from the hardware keys of an android phone.
Don’t know what you mean? You can already use Assist as your assistant on Android.
