Hi there
I would like to have an LED on the powerplug to show the status of the light.
I can make this work without any issues with a switch, but if I enter the same commands for a light, I get a no-no.
So I have two buttons, two relays, and two LED’s.
The code looks like this currently:
First I have the buttons defined.
Then the outputs, followed by the switch, and finally the light.
binary_sensor:
- platform: gpio
internal: true
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: true
on_press:
- switch.toggle: relay1
- platform: gpio
internal: true
pin:
number: GPIO12
mode: INPUT_PULLUP
inverted: true
on_press:
- light.toggle: relay2
output:
- platform: esp8266_pwm
pin:
number: GPIO13
inverted: true
pin:
number: GPIO2
inverted: true
- platform: gpio
pin: GPIO16
switch:
- platform: gpio
pin: GPIO14
on_turn_on:
- output.turn_on: led1
on_turn_off:
- output.turn_off: led1
light:
- platform: binary
output: light_relay
# on_turn_on:
# - output.turn_on: led2
# on_turn_off:
# - output.turn_off: led2
The on_turn_on works fine with switches, but if I enter it into the light I get the message:
So how do I get this working?
