Make light details collapsable and collapsed by default in automation and script editors
The automation and script editors are amazing but can become huge with longer automations or scripts, making it difficult to visualize the flow without going into the trace view.
I’ve found that a lot of the space is due to the long details section in light.turn_on, light.toggle and similar which I usually don’t use or don’t edit once set. It would be nice if these sections could be collapsable and collapsed by default to make the editor more usable.
It would be great to be able to collapse any part of the automation really, not just the light section. It gets rather confusing to work through automations with multiple triggers and options. There’s very little visible distinction between sections on the automations screen, which just makes long or complicated automations difficult to work with.
+1 after seeing 2022.5 I was expecting to find this inside, and then extremely surprised that this is the closet feature request I can find for it.
Some of my automations are huge. They are as lean as can be, but with often 10 different choices inside all with various conditions etc, scrolling down to find the right one is an absolute nightmare. Desperately need to be able to collapse each section to probably navigate through.
