Is there a way to make a regular smart bulb fade on when it is turned on, like the hue bulbs, instead of just suddenly flashing on? I saw a few things about having the light slowly turn on in the morning or for slow fade times, but nothing for just make it fade on over ~1 sec when it is turned on in home assistant.
You could try transition
(also see Developer Tools → Services)
Example for a 30 seconds fade-in until full brightness:
service: light.turn_on
entity_id: light.YOURLIGHT
brightness: 254
transition: 30
This seems to be a working method, I tested it over 30 seconds with the hue bulbs, but sadly it seems to be in compatible with Tuya based bulbs using the Tuya V2 integration, oh well. Thanks!!
I have guessed already that it depends on the particular lamp.
