Hi fellow makers,
I had the idea to automate my herb garden. Basically I have 4 humidity sensors in 4 different flowering pots measure the humidity and 4 pumps acting accordingly.
Now, for the logic behind that, i wanted create three different profiles for the flowering pots, namely “dry”, for herbs like thyme, “moist” for herbs like basil and something in-between. The plan was to fix these profiles in a database and make the sensors read them before pumping.
So for example, the flow would be:
Measuring humidity every hour → Pot 2 has an actual humidity of 17% → check in DB how much the profile expects the pot to have (for example 30% for a medium profile) → Pump for Pot 2 is activated for 10 seconds → rinse and repeat every hour until expected value is reached.
I understood that the standard Home Assistant DB can be manipulated with the average DB Tool but is there maybe also a possibility to do it directly from the WebUI? For example if I replant an herb to another pot and I want to change said pot from “dry” to “medium”.
Or does anyone have a completely different idea for the architecture to save said profiles?
Any nudge in the right direction is much appreciated!
Additional Info:
Running Home Assistant and esphome in Docker on Ubuntu.
Sensors and Actors are connected to an ESP32.
