Hi, I’m new to home assistant. Coming from openhab and liking it so far.
I’m struggling with the following.
I have a PLC where real switches and lights are connected to.
The PLC is master so everything works even when hass is down.
To control a light I have 2 variables on modbus:
Status: actual state of light (on/off) = binary sensor in hass
Control: to toggle the state = switch in hass
The switch always has to follow the state of the binary sensor.
I only want to put the switch on the dashboard, and the switch should always be the actual state of the binary sensor.
Example:
Light is off, i switch on light via switch in the wall, the binary sensor changes to on, the switch in hass also has to change to on.
It works perfectly, but I have about 50 lights so it’s many lines for something simple.
Is there a way to make this a bit more compact and cleaner?
I also can’t figure out how I can put it all in code, I made this in the UI but would like to put it all in a seperate yaml file.
I looked up this link: Automation YAML - Home Assistant
But I can’t get it to work…
Piece of the example below:
# Example of entry in configuration.yaml
automation my_lights:
# Turns on lights 1 hour before sunset if people are home
# and if people get home between 16:00-23:00
- alias: "Rule 1 Light on in the evening"
It complains that I can’t use my_lights… Can someone point out why?
This should get your code working, but I think it is not really what you want because it stays in a single file.
# This is very important and I'm not sure if you have this in your configuration.yaml file too.
# Labeled automation block
automation kitchen:
- trigger:
- platform: ...
This could be your file structure:
when you’re using automation: !include_dir_list ./automations in your configuration.yaml
Do you also have an example of multiple automations in 1 file?
I have been fiddling with it for an hour with name and alias properties but I can’t get it to work.
But I would like this piece of code multiple times in the same file… Really can’t get it to work…
Also another question, is it possible to make this like a kind of function I could call and just pass parameters?
Like: modbusSwitch:=updateSwitch(modbusSensor) or updateSwitch(modbusSensor,modbusSwitch)?
This will work only if the last character in the binary_sensor’s name corresponds to the last character of the corresponding switch’s name. In other words, if binary_sensor.wago_sensor3 corresponds to switch.wago_switch3.
Hello @Robbe1991 , I am currently facing the same problem. Have you found an easy solution or written one yourself? Also, I’m still new to HASS. Did you have to create an automation for each button as well?
Currently, this solution doesn’t work for me as expected. How should I implement this solution?
