Oligarch
(Oleksandr)
June 3, 2023, 10:48pm
1
Please help me convert my intercom into a smart one using ESP. This is my first project on ESP. Tell me which module is better for this purpose, what and where I need to connect… Below, I will provide you with photos of the handset and the schematic diagram.
nickrout
(Nick Rout)
June 4, 2023, 1:58am
2
What are you actually trying to automate?
Oligarch
(Oleksandr)
June 4, 2023, 11:38am
3
I want to receive notifications when someone rings the intercom and be able to open the door.
nickrout
(Nick Rout)
June 4, 2023, 10:17pm
4
Opening the door, put a relay over the pins for open door and fire it from the esp.
Detecting speech, not sure.
I guess the reed switch is for detecting whether the handset is mounted? I assume there’s a handset?
Oligarch
(Oleksandr)
June 5, 2023, 11:21am
6
Yes. This electronic circuit is inside the handset. A magnet is installed in the platform on which the handset is suspended.
And then does the person also need to press the button after they have picked up the handset to initiate communication?
for notification, measure the voltage spike when the intercom door button is pressed (when you hear the ring), step it down to 5 volts using a DC step down module, then you can have it in esphome, you can use the following code:
- platform: gpio
pin:
number: D2
mode:
input: true
pullup: true
name: "Building Doorbell"
filters:
# Small filter, to debounce the button press.
- delayed_on: 100ms
- delayed_off: 100ms
Oligarch
(Oleksandr)
June 5, 2023, 9:11pm
9
The connection opens automatically after lifting the handset. The button must be pressed to open the door
Oligarch
(Oleksandr)
June 9, 2023, 9:40pm
10
I suspect I need two relays. One for closing the reed switch, which simulates picking up the handset, and the other for the door opening button. I found such a ready-made module with two relays:
This module is based on ESP-01. Who can tell if it has an ADC input for voltage measurement?
nickrout
(Nick Rout)
June 9, 2023, 11:03pm
11
Oligarch
(Oleksandr)
June 9, 2023, 11:40pm
12
Are there any external ADC modules that can be connected to ESP-01? When an incoming call occurs, there is a voltage appearing on the line. I need to somehow capture this moment…
nickrout
(Nick Rout)
June 9, 2023, 11:42pm
13
What voltage appears? Could be as simple as a transistor to a regular gpio?
Oligarch
(Oleksandr)
September 12, 2024, 11:55pm
14
I finally had the chance to work on my project to integrate an old intercom into Home Assistant. This is my first ESP project, and I’m excited to share the results.
I’m pleased to report that the final result has been highly satisfying. The system works flawlessly and responds 100% of the time, meeting all my expectations.
Thanks for all the help and support in this topic.
Components Used:
ESP_Relay_x2_V1.2 board with ESP-01-1M
ESP32 CH340 Dev board
INA226 module
Transparent plastic junction box
Wiring Details:
INA226 to ESP32:
SDA → ESP32 SDA (GPIO21)
SCL → ESP32 SCL (GPIO22)
VCC → 3.3V of the ESP32
GND → GND of the ESP32
INA226 Internal Connections:
VBUS** → LINE+ (Intercom)
GND** → LINE- (Intercom)
Relay Board Wiring:
Relay 1 (Handset Simulation):
NC → Reed Switch in Series
COM → Reed Switch Circuit
Relay 2 (Button Press):
NO → Button Circuit in Parallel
COM → Button Circuit
How It Works:
The INA226 module monitors the voltage on the intercom line to detect incoming call.
Home Assistant sends a actionable notification when a call is detected.
Notifications let you Open or Dismiss the call. Open simulates lifting the handset and pressing the door button. Dismiss breaks the line to end the call.
Code:
ESP32 Configuration:
esphome:
friendly_name: Intercom CallTracker
esp32:
board: esp32dev
framework:
type: arduino
logger:
api:
encryption:
key: "***"
ota:
- platform: esphome
password: "***"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Intercom-Calltracker"
password: "***"
web_server:
captive_portal:
i2c:
sda: GPIO21
scl: GPIO22
scan: true
- platform: wifi_signal
name: "WiFi signal strength"
update_interval: 60s
entity_category: "diagnostic"
device_class: signal_strength
- platform: internal_temperature
name: "Internal Temperature"
- platform: ina226
address: 0x40
shunt_resistance: 0.01 ohm
max_current: 3.2A
adc_time: 140us
adc_averaging: 128
update_interval: 3s
bus_voltage:
name: "INA226 Bus Voltage"
binary_sensor:
- platform: status
device_class: sound
lambda: |-
if (id(ina226_bus_voltage).state > 1) {
return true;
} else {
return false;
button:
- platform: restart
ESP-01 Configuration:
esphome:
friendly_name: Intercom ControlUnit
esp8266:
board: esp01_1m
logger:
api:
encryption:
key: "***"
ota:
- platform: esphome
password: "***"
wifi:
ap:
ssid: "Intercom-Controlunit"
password: "***"
web_server:
captive_portal:
binary_sensor:
- platform: status
update_interval: 15s
button:
- platform: restart
switch:
- platform: gpio
name: 'Handset pick up'
pin:
number: GPIO0
inverted: true
- platform: gpio
pin:
number: GPIO2
inverted: true
on_turn_on:
- delay: 500ms
- switch.turn_off: button_press
Automation Code:
alias: Notify_Action
description: >-
Sends a notification when an incoming intercom call is detected. If the
input_boolean.intercom_open_once is enabled, the door opens automatically and
a confirmation notification is sent. Otherwise, the user receives a
notification with options to either open or dismiss the call.
- platform: state
entity_id:
- binary_sensor.incomingcall
to: "on"
- choose:
- conditions:
- condition: state
entity_id: input_boolean.intercom_open_once
state: "on"
sequence:
- action: script.control_intercom
do_action: open
- action: input_boolean.turn_off
data: {}
- domain: mobile_app
type: notify
device_id: your_device_id
title: |
<b>Intercom</b>
message: |
<b><span style="color: #F07857">Automatically Opened</span></b>
tag: Intercom_IncomingCall
sticky: "true"
color: "#87CEEB"
channel: IntercomNotification
ledColor: blue
notification_icon: mdi:deskphone
default:
- variables:
action_open: "{{ 'OPEN_' ~ context.id }}"
action_dismiss: "{{ 'DISMISS_' ~ context.id }}"
type: notify
title: |
<b>Intercom</b>
message: |
<b><span style="color: #006400">Incoming Call</span></b>
sticky: "true"
color: "#87CEEB"
channel: IntercomCall
ledColor: blue
actions:
- action: "{{ action_open }}"
title: Open
- action: "{{ action_dismiss }}"
title: Dismiss
- wait_for_trigger:
- platform: event
event_type: mobile_app_notification_action
event_data:
- platform: event
event_data:
- platform: state
entity_id:
to: "off"
for:
seconds: 1
timeout:
minutes: 1
seconds: 5
continue_on_timeout: true
- choose:
- conditions:
- condition: state
entity_id: binary_sensor.incomingcall
state: "off"
for:
seconds: 1
sequence:
type: notify
title: |
<b>Intercom</b>
message: "<b><span style=\"color: red\">Call Interrupted</span></b>"
sticky: "true"
color: "#87CEEB"
ledColor: blue
- stop: Call Interrupted
- conditions:
- condition: template
value_template: "{{ wait.trigger.event.data.action == action_dismiss }}"
sequence:
do_action: dismiss
- conditions:
value_template: "{{ wait.trigger.event.data.action == action_open }}"
sequence:
do_action: open
type: notify
message: clear_notification
mode: single
Script Code:
alias: Control_Intercom
sequence:
- choose:
- conditions:
value_template: "{{ do_action == \"open\" }}"
sequence:
- action: switch.turn_on
metadata: {}
data: {}
entity_id: switch.intercom_controlunit_handset_pick_up
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
metadata: {}
data: {}
entity_id: switch.intercom_controlunit_button_press
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
- action: switch.turn_off
metadata: {}
data: {}
- conditions:
value_template: "{{ do_action == \"dismiss\" }}"
sequence:
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
metadata: {}
data: {}
description: ""
sviat_d
(Sviatoslav)
August 20, 2025, 7:45am
15
Hello, @Oligarch . Thank you for sharing your experience. Can you tell how your project was powered? As I understood the intercom handset isn’t powered all the time so you can’t get power from there. Have you used batteries or is there some other useful advice?
Oligarch
(Oleksandr)
August 20, 2025, 8:37am
16
In my case I couldn’t draw power from the intercom itself since it didn’t provide enough current. Instead, I had a 220V cable coming out of the wall from an old doorbell installation near the front door. I disassembled a regular 2A phone charger, soldered a USB cable to the charger board and the 220V leads, and placed everything inside a small enclosure from AliExpress.
