Make value 0 if unavailable
I have a solar converter from omnik.
At night it is unavailable.
Is it possible to show 0 instead of unavailable as a value.
Something like if sensor is unavailable then make 0
I don’t know how to figure this out!
Template sensor:
template:
  - sensor:
      - name: "Solar output with zero"
        state: "{{ states('sensor.your_real_sensor')|float(0) }}"
The default 0 value on the float filter will be used if the state of the other sensor can’t be converted to a number.
Ok but now this is only needed if the sensor goes to unavailable
Use it all the time. It’ll show the sensor value when it can be evaluated as a number.
It’s possible your original sensor can be set up to solve this for you, but as you’ve omitted to provide any details I can’t tell.
i know question was short.
i was busy too long with it
i try your solution tonight
Thank you! i figured it out at your way!
