Doorbell using Fibaro implant FGBS-222
Use a Fibarro implant FGBS-222 device to add zwave to your standard doorbell.
The doorbell will remain working normally, but is gets integrated with Home Assistant. I used some automations that create a snapshot from the servailance camera when someone presses the doorbell, and sends a notification including the image…
Hardware
Specifications:
- Normal functioning doorbell using the existing pushbutton and ringer.
- Makes use of the existing standard 8v AC transformer
- Doorbell becomes available in Home Assistant as a sensor
- Doorbell can be actuated from within a Home Assistant automation.
Partlist:
- EB1: Fibaro FGBS-222
- D1-D4: Diode 1N4001
- D5: Diode 1N4007
- R1: Resistor 249 Ohm
- RY1: Relais 6v (coil resistant apprx. 60 Ohm, change R1 when different)
- C1: capacitor minimum 2200 uF
- ST1-ST3: wire connector
- Veroboard print
- Housing.
Connections:
- ST1: Standard 8v AC transformer (polarity is not important since it is AC)
- ST2: Push button (some pushbuttons have a built in light. You have to disconnect the light for this application to work)
- ST3: Standard ringer or gong
Fibaro FGBS-222
- P to + DC (blue wire)
- GND to - DC (brown wire)
- IN1 to push button. (yellow wire)
(the other wire from the push button connects to - DC ) - OUT1 to R1
- OUT1G to - DC
Automations
I created a simple automation that gets triggered by the doorbell, makes a snapshot and sends a notification like this:
alias: Deurbel foto
description: Als de deurbel gaat, maak een foto en stuur naar Telegram
- platform: device
type: turned_on
entity_id: switch.smart_implant
domain: switch
condition: []
- service: camera.snapshot
filename: /config/www/snapshots/snapshot.jpg
entity_id:
- camera.dahua_mediaprofile_channel1_mainstream
- delay:
seconds: 2
- service: persistent_notification.create
title: Somebody ringing the door!
message: ''
mode: single
