Could you elaborate on what you mean by “go in to one icon”? Even though I used SmartThings for quite a while before switching to HA, it’s not intuitively obvious to me what you’re looking for.
right now i have 3 different icons showing, temp in one, battery % in one and if the sensor is open/closed in one. i like to have it so temperature and battery are in the same icon as the open/close one. so if i click on the open / close icon or put my mouse on it, then i will see the % of battery and the temperature.
You can kind of do that with a group if you make it visible. Otherwise sounds like you want a sensor whose state is the same as the open/ close sensor and has attributes whose values are the same as the states of the other two. It probably wouldn’t be too hard to make a custom sensor like that. Don’t know how to do it with existing components, though.
