Our cats are chipped with an Rfid tag. I want to read out those tags each time they walk through the cat door to get an idea about their nocturnal activity.
The plan is to use an rfid reader connected to an esp32. The esp32 will send data (the rfid id) to a hass webhook.
In hass I will do some kind of automation to pick up this webhook signal.
In the end I’d like to have hass to register ( in the database) each time a cat is scanned.
And I want a card in the UI displaying info like this:
Cat A: last seen: 16 hrs ago
Cat B: last seen: 1 hr ago
And at that last part I get kind of stuck and wonder whether you guys have any suggestions:
I don’t know if and/or what kind of component I should use to display these
“scanned events”. I guess it should be some kind of sensor, but can’t seem to find the correct one.
@stevenhorner Unfortunately you were right. Most rfid scanners (like the rdm6300 I have) operate on a different frequency than the tag which is in my cat.
I have a tag which works with both the rdm6300 and the cat scanner. That’s why I made the (now false) assumption that it would work. But scanning my cat with the rdm6300 doesn’t do anything unfortunately.
Helloo there, after a lot of research i finally heard of a person (you) that’s looking for something similar as me . I want to somehow make an rf detector that will alarm me (by noise- alarm and mobile notification) when my cat tries to pass through the entrance door. The purpose here is to improve safety for my cat, as i share the house with more people and i’d like to exclude the possibility of my cat escaping the door because someone did not pay the proper amount of attention. I went through your thread and that you tube video someone replied to you. Do you know how this idea of mine should be appliable? Myself, i don t know how to make an automated system like that but since i get some perspective here, i could easily find someone to make it for me!
Thanks a lot, in advance, for reading my strange request
Hey what happened with this? I just started adding ESPhome devices to my set up and want a cat tracker and presence detection. Apple AirTags are quite large for a cat who isn’t used to wearing a collar at all.
