Hello, I encountered an error after updating to 2024.8. Whenever I create an automation in the UI and save it, every automation becomes uneditable, and I receive an error stating, “This automation cannot be edited from the UI because it is not stored in the automations.yaml file, or doesn’t have an ID.” To resolve this, I must either duplicate and edit each automation or modify the automations.yaml file in any manner, even adding a new line seems to correct the issue.
I suspect this may be related to recent automation rewrites, although I’m not entirely certain. I haven’t attempted safe mode since I’m connected via Cloudflare tunnel and not on a local network at the moment. My configuration.yaml is nearly default, except for the added sensors and the configuration of trusted proxies.
Has anyone encountered this issue as well? I tried to google the error, but no good results came up.
Attaching configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
- platform: rest
name: Twitch Follower Count
resource: https://api.twitch.tv/helix/channels/followers?broadcaster_id=<redacted>
headers:
Authorization: !secret twitch_key
Client-ID: !secret twitch_ID
value_template: '{{ value_json.total }}'
scan_interval: 5
- platform: rest
resource: https://api.twitch.tv/helix/users?id=<redacted>
headers:
value_template: '{{ value_json.data[0].display_name }}'
scan_interval: 300
and automations.yaml
- id: '1723124212464'
alias: <redacted> dosiahla 10 follows na twitchi
description: ''
- platform: numeric_state
entity_id:
- sensor.twitch_follower_count
for:
hours: 0
minutes: 1
seconds: 0
above: 9
condition: []
- device_id: 9fd2f20ac712c5ec27fbeef9a300d682
domain: mobile_app
type: notify
message: "\U0001F389Gratulujem lásočka"
title: Dosiahla si 10 followerov!
- action: light.turn_on
metadata: {}
rgb_color:
- 255
- 0
- 208
brightness_pct: 100
entity_id: light.triones_0205110006ec
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- action: light.turn_off
metadata: {}
data: {}
mode: single
- id: '1723124495158'
alias: Notifka na vypnutú TV
description: ''
- platform: device
type: turned_off
device_id: 6f3302e4c2d88c7a6f9084825501b411
entity_id: c76926672c5017c92480a7a9b80eeff3
domain: remote
condition: []
- metadata: {}
message: TV sa práve vypla.
action: notify.mobile_app_<redacted>_iphone
- action: notify.mobile_app_samsung_galaxy_s22_ultra_5g
mode: single
- id: '1723183227455'
alias: novy followik
description: ''
- platform: state
entity_id:
condition:
- condition: template
value_template: '{{ trigger.from_state.state|int < trigger.to_state.state|int
metadata: {}
data: {}
device_id: 8aa660f9435ce8b975a8b342365c787c
metadata: {}
effect: rb_cross_fade
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
metadata: {}
data: {}
mode: single
