Making an entity a device
Hi!
I’ve got the fibaro component installed and all my fibaro devices shows up as entities.
But i cannot use them in HA scenes?
can I create devices out of my fibaro entities?
How can I do that?
Bump, anyone?
What do you mean you can’t use them in scenes? Entities can be used in scenes https://www.home-assistant.io/docs/scene/
What devices do you have ? Lights / Switches / Something else ?
If you look at unused entities, do you not have a switch.fibaro_fgwpef_wallplug_f01 or a light.fibaro_dimmer_01 or similar ?
Thank you!
Couldn’t find that topic when searching!
But is there no way of making an entity a device so that it can be used in the UI better? Assigned to a room etc?
Im in a similar boat - pile of entities but no devices to action :neutral_face:
what does this mean?
Via the UI
Configuration -> Areas (can only add Devices)
Configuration -> Automation (trigger need to be Devices)
How do I ?promote? my configuration.yaml Entities to a Devices?
That is not the case. Use a state trigger with entities :
I was dumbing my way though the wizard, thank you.
Automation :white_check_mark:
Areas don’t seem to be of much use at present.
