Hey there!
I’m new to Home assistant and I’m setting up all my 70+ devices ^^,
I have a bunch of roller shutter and awning devices, which work great with Home Assistant, and are exposed really well in Google Home. They all are controlled through the same zwave device (fibaro roller shutter), but I set the device class for them differently (for shutters I use shutter, for awnings I use awning).
Using the right class makes things work well on Google Home side. If I use shutter for everything, then Google Home gets confused when asking it to close the awnings.
However, the way awnings are displayed in HA is not great, because it matches an horizontal awning (like a curtain) and I have vertical awnings (that close from top to bottom), so I would like to change these controls to the ones used for shutters.
I’ve tried using customize, as follow:
in configuration.yaml
homeassistant:
customize: !include customize.yaml
customize_domain: !include customize_domain.yaml
customize_glob: !include customize_glob.yaml
in customize_glob.yaml:
"cover.toldo*":
device_class: shutter
That works, and now the awning devices look like a shutter. However, that also modifies how these are exposed to Google Home.
I guess that if I want to modify the controls without modifying the device_class itself, I need to customize other attributes or maybe create a custom component and use it somehow. But after hours browsing the documentation, I haven’t managed to find anything.
Any help, or an example?
Cheers,
