I am writing a custom LVGL Widget, based on meter
to display a compass, for displaying wind direction.
There seems to be a common pattern whereby a widget declares itself as being 100% high and wide, allowing the parent container to specify the actual size.
I am following this pattern, but find that I need to know the size that has been provided in order to calculate sizes internally.
To solve this, I am passing in the size as a variable, but I do not like this approach.
This is how I place the widget:
- obj:
height: 140
width: 140
align: CENTER
border_width: 0
pad_all: 0
scrollbar_mode: "OFF"
widgets:
- meter: !include { file: widgets/compass-rose.yaml, vars: {id: "compass", diameter: 140} }
See how the size value is used 3 times :-/
Here is the sensor:
- platform: homeassistant
entity_id: $wind_bearing_sensor #### a reference to your actual wind bearing sensor
on_value:
- lvgl.indicator.update:
value: !lambda |-
return x > 180 ? x - 180 : x + 180;
- lvgl.label.update:
text: !lambda |-
switch(int(x)) {
case 0 ... 11: return "N";
case 12 ... 34: return "NNE";
case 35 ... 56: return "NE";
case 57 ... 79: return "ENE";
case 80 ... 101: return "E";
case 102 ... 124: return "ESE";
case 125 ... 146: return "SE";
case 147 ... 169: return "SSE";
case 170 ... 191: return "S";
case 192 ... 214: return "SSW";
case 215 ... 236: return "SW";
case 237 ... 259: return "WSW";
case 260 ... 281: return "W";
case 282 ... 304: return "WNW";
case 305 ... 326: return "NW";
case 327 ... 348: return "NNW";
default: return "N";
Here is the widget:
#- meter:
align: CENTER
height: 100%
width: 100%
border_width: 0
pad_all: 0
scales:
- range_from: 1
range_to: 360
angle_range: 360
rotation: 0
ticks:
width: 1
count: 13
length: 5
indicators:
- image:
src: direction_pointer
pivot_x: 8
pivot_y: ${1 + (diameter/2)} #### this is where I need the size set by the parent
value: 0
- arc:
color: screen_black
r_mod: -16
width: 16
start_value: 1
end_value: 360
widgets:
- obj: # to cover the middle part of meter indicator line
height: 16
width: 16
radius: 8
align: CENTER
border_width: 0
bg_color: screen_white
pad_all: 0
- label:
align: CENTER
text_color: screen_black
text_font: montserrat_24
text: " "
- label:
text: "N"
text_color: screen_white
text_font: montserrat_14
align: TOP_MID
y: 17
- label:
text: "S"
align: BOTTOM_MID
y: -16
- label:
text: "E"
align: RIGHT_MID
x: -20
- label:
text: "W"
align: LEFT_MID
x: 16
I find I require the diameter
for the the image I am using for the indicator
, it needs to have it’s pivot_y
set to half the diameter, if it is going to be resizable. (A tall thin image with an arrow at the top)
I tried to calculate this using SIZE_CONTENT
but it did not compile.
Is there another way to doing this?
Another question is how to specify colours when this may be shown on LCDs or E-Paper, where the black and white need inverting. What is the cleanest approach?
