Making sure a switch is on
After a powercut my Wemo devices remain off - which is annoying
Does anyone know a way/automation to makesure it is kept on
- id: Make sure Billion is on
  alias: Make sure Billion is on
    platform: state
    entity_id: switch.billioninternet
    to: 'off'
    for:
      minutes: 5
    service: homeassistant.turn_on
If you always want it to be on, then why are you using a switch? :stuck_out_tongue_winking_eye:
But seriously, if you always want the switch to be turned on when HA starts, then:
    platform: homeassistant
    event: start
Good question!
But there is a reason. I use the switch to hard reset the router if the internet goes down. So it’s like a local reboot after all other internet repair attempts fail.
Only issue is after a power cut the switch is off.
Is there a way to detect if the switch is off for a period of time and turn it on?
does the switch report its state to home assistant? That is, if you flip the switch on, does the GUI change to show it’s on? If so:
    platform: state
    state: "off"
    for:
      minutes: 5
That will turn the switch on if it has been off for more than 5 min. It looks like you had it right the first place, does it not work?
Yes.
  platform: state
  entity_id: switch.your_switch
  to: 'off'
  for:
    seconds: 30
You are missing the entity_id in the state trigger.
ah yes… corrected
Thanks @ha_steve however that results in an error
Configuration invalidCHECK CONFIG
Invalid config for [automation]: [state] is an invalid option for [automation]. Check: automation->trigger->0->state. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
Thanks @tom_l - but how is that different from what I posted
It’s not. It should work.
Also Steve’s answer has state: 'off' instead of to: 'off' in the trigger, this is incorrect and is causing the error you see.
Thanks @tom_l and @pnbruckner
I think a combination of the following should work
    platform: state
    to: 'off'
    for:
      minutes: 5
- id: Make sure Billion is on at HA Startup
  alias: Make sure Billion is on at HA Startup
    event: start
sorry! Teaches me to respond in a hurry!
