Here’s a quick bit of code I wrote which accepts an AWS Lambda event and submits it to Home Assistant’s event bus so that you can do automations based on Lambda events. A perfect use of this is with the new AWS IoT Dash Button (which @JshWright helpfully points out costs about $0.02 per button press). After pressing the button I see the message appear in Home Assistant after about 8 seconds.
I’ve also used this same code to get notifications in Home Assistant when my security service calls to tell me I have a new package, delivery or guest.
Just create a new Lambda function, skip the blueprint, put this in, set the role to be basic execution. You also need to change the variables at the top. If you are using HTTP change all occurrences of https to http.
* The following JSON template shows what is sent as the payload:
"serialNumber": "GXXXXXXXXXXXXXXXXX",
"batteryVoltage": "xxmV",
"clickType": "SINGLE" | "DOUBLE" | "LONG"
* A "LONG" clickType is sent if the first press lasts longer than 1.5 seconds.
* "SINGLE" and "DOUBLE" clickType payloads are sent for short clicks.
* For more documentation, follow the link below.
* http://docs.aws.amazon.com/iot/latest/developerguide/iot-lambda-rule.html
const HOST = 'myhome.com';
const PASSWORD = 'myapipassword';
const EVENT_NAME = 'dash_button.pressed';
var https = require('https');
exports.handler = (event, context, callback) => {
console.log('Received event:', event.clickType);
var post_options = {
host: HOST,
path: '/api/events/'+EVENT_NAME,
method: 'POST',
headers: {
'Content-Type': 'application/json',
'X-HA-Access': PASSWORD
var post_req = https.request(post_options, function(res) {
res.setEncoding('utf8');
console.log('Home Assistant response status code', res.statusCode);
res.on('data', function (chunk) {
console.log('Home Assistant Response: ' + chunk);
res.on('end', function(){
callback(null);
post_req.on('error', function(err){
console.error('Error when notifying Home Assistant!', err);
callback(err);
post_req.write(JSON.stringify(event));
post_req.end();
