Mammotion Luba integration
hooking in…also interested :wink:
How do I install the HA-Luba integration? I searched in HACS and it doesn’t come up. I tried adding the custom repo and it gives me an error saying it “already exists in the store”
anyone knows how long till wifi will be supported? Any eta?
If Mammotion shows up in HACS on the “Integrations” tab, you should be able to add the device through the normal “Add Integration” button in “Settings->Devices & services”. Search for “Mammotion”.
Yes Michael and I are working on a HA integration, you can try it out now. GitHub - mikey0000/Mammotion-HA: Home Assistant integration for Luba lawn mower
There is a ReadMe on the front page that provides all the steps needed to get you up and running. There is also a link to our discord channel if anyone else needs support
Does anybody know where to find the Bluetooth Mac address of the Luba that is required to setup this promising integration ?
I get a list of devices but which one is Luba ?
***************************** EDIT: OK SOLVED !!! ************************************
So I guess this will only work if the bluetooth of the HomeAssistant Computer is in reach of the Mammotion Robo? I have my HomeAssistant Computer in the Cellar and now wwy bluetooth reaches the Robo.
You can also use Bluetooth proxies. Bluetooth Proxy — ESPHome
