I set up the manual alarm control panel with MQTT. Then I setup telegram and notify with it. Made few command so that I can check with telegram what is the status of lights. But the problem comes with the alarm control panel. If it is deactivated telegram notify works fine. If alarm is activated (home or away) I get an error message below.
Any suggestions what to do?
ERROR (Thread-20) [homeassistant.components.telegram_bot] Error sending message: Can’t parse entities in message text: can’t find end of the entity starting at byte offset 81. Args: (435656865, ‘Home\nAll HUE lights are off. Some of the SWITCH lights are on. Alarm state: armed_home.’), kwargs: {‘reply_to_message_id’: None, ‘disable_web_page_preview’: None, ‘reply_markup’: None, ‘timeout’: None, ‘parse_mode’: ‘Markdown’, ‘disable_notification’: False}
My configuration.yaml:
alarm_control_panel:
- platform: manual_mqtt
state_topic: home/alarm
command_topic: home/alarm/set
telegram_bot:
- platform: polling
api_key: !secret telegram_api_key
allowed_chat_ids:
- !secret telegram_chat_id_1
notify:
- name: kirka
platform: telegram
chat_id: !secret telegram_chat_id_1
My automation.yaml:
- id: telegram_bot_home_status
alias: telegram bot home status
hide_entity: true
initial_state: 'on'
- platform: event
event_type: telegram_command
event_data:
command: /home_status
- service: notify.kirka
data_template:
title: Home
message: >
{% if is_state("group.all_lights", "on") %}Some of the HUE lights are on.{% else %}All HUE lights are off.{% endif %} {% if is_state("group.all_switches","on") %}Some of the SWITCH lights are on.{% else %}All SWITCH lights are off.{% endif %} Alarm state: {{ states("alarm_control_panel.ha_alarm") }}.
Example messages coming to telegram:
/home_status
kirka_bot, [17.10.17 20:18]
Home
All HUE lights are off. Some of the SWITCH lights are on. Alarm state: disarmed./home_status
Home
All HUE lights are off. Some of the SWITCH lights are on. Alarm state: pending.
