Manual alarm system setup for Homekit (Status tamper & fault possible?)
Hi all together,
I am pretty new to HA, I just switched from ioBroker 2 weeks ago.
At the moment I am working on my virtual AlarmSystem in HA. Since i already have a professional wired AlarmSystem in my House I just need to get the states to HA.
I have a Honeywell MB-Classic MB100 with DS6700 and this sends me all kind of states via VdS2465 protocol to ioBroker. From there I send mqtt messages to HA, since HA hasn’t a direct way to receive the data from the alarmsystem.
Anyhow, I can send basically any kind of message to HA and already got a virtual alarm_control_panel up and running in HA. This is shown me also in Homekit.
But in HA i can only set these states through automations:
disarmed
armed (away, home, etc.)
trigger
What i would like to be able is to distinguish the alarms, since there is more then just “alarm”.
Is it possible to set different states like burglary/intrusion, tamper, system fault, battery fault. etc…
With iobroker’s yahka adapter (for homekit) it was at least possible to set tamper and fault…
Maybe someone has an idea how to realize. Thank you very much for helping.
For example: what does “metadata” in the automations do?
- action: alarm_control_panel.alarm_trigger
            metadata: {}
Here are some snippets of my configs for better understanding:
iobroker mqtt messages to HA (javascript):
on({ id: [].concat(EMA_Alarm_Datenpunkt), change: 'ne' }, async (obj) => {
  let value = obj.state.val;
  let oldValue = obj.oldState.val;
  if (EMA_Alarm_Signal == true) {
    // EINBRUCH Benachrichtigung
    sendTo('mqtt.1', 'sendMessage2Client', { topic: 'Alarmanlage/MB100/alarm/intrusion', message: '{ "state": "intrusion",   "details": "sensor_alarm" }', retain: true });
  } else if (EMA_Alarm_Signal == false) {
    sendTo('mqtt.1', 'sendMessage2Client', { topic: 'Alarmanlage/MB100/alarm/intrusion', message: '{ "state": "ok",   "details": "" }', retain: true });
HA sensor for intrusion:
- name: "EMA Alarm Zustand"
    unique_id: "EMA_alarm_zustand"
    state_topic: "Alarmanlage/MB100/alarm/intrusion"
    value_template: "{{ value_json.state }}"
    json_attributes_topic: "Alarmanlage/MB100/alarm/intrusion"
Manual alarm system in HA:
- platform: manual
  unique_id: EMA_01
  code: "1234"
  arming_time: 0
  delay_time: 0
  trigger_time: 120
  arming_states:
    - armed_away
    - armed_home
  disarmed:
    trigger_time: 0
  armed_home:
    arming_time: 0
    delay_time: 0
  armed_away:
    arming_time: 0
    delay_time: 0
Automation HA:
alias: EMA Zustände schalten
description: ""
triggers:
  - trigger: state
    entity_id:
      - sensor.ema_scharf_zustand
    to: away
    attribute: details
  - trigger: state
    entity_id:
    attribute: details
    to: home
  - trigger: state
    entity_id:
    to: disarmed
  - trigger: state
    entity_id:
      - sensor.ema_alarm_zustand
    to: intrusion
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - armed_away
        sequence:
          - action: alarm_control_panel.alarm_arm_away
            metadata: {}
              code: "1234"
              entity_id: alarm_control_panel.alarmanlage
      - conditions:
            id:
              - armed_home
        sequence:
          - action: alarm_control_panel.alarm_arm_home
            metadata: {}
              code: "1234"
      - conditions:
            id:
              - disarmed
        sequence:
          - action: alarm_control_panel.alarm_disarm
            metadata: {}
              code: "1234"
      - conditions:
            id:
              - intrusion
        sequence:
            metadata: {}
              code: "1234"
mode: single
