pplucky
(Pplucky)
September 22, 2017, 1:40pm
1
Hello everyone.
I have defined a Manual Alarm like the following:
alarm_control_panel:
- platform: manual
pending_time: 30
trigger_time: 30
Then I have an automation to trigger it while armed away like the following:
- alias: "Alarm trigger while armed away"
- platform: state
entity_id: binary_sensor.door_window_sensor_xxxxxxxxxxxxxx
to: 'on'
- platform: state
entity_id: group.all_motion
to: 'on'
condition:
condition: state
entity_id: alarm_control_panel.home_alarm
state: 'armed_away'
- service: input_boolean.turn_off
entity_id: input_boolean.mute_gateway_sounds
- service: alarm_control_panel.alarm_trigger
- service: script.play_sound
ringtone_id: 10004
ringtone_vol: 50
delay: 2
- service: notify.iOS
message: 'Alarm fired away'
title: 'Home Assistant alert'
push:
badge: 5
category: "ALARM"
If I understood well the documentation , with my configuration alarm should not be triggered until 30 seconds had passed since the triggering conditions and should trigger only for 30 seconds.
In a regular alarm system (not software based), you’re supposed to have time after arming the alarm (to avoid it to be triggered before you actually leave - this one is working fine) and also time before triggering it (to avoid it triggering immediately, to give you time to disarm it - this one is NOT working fine).
Am I missing something here, or is my alarm misbehaving?
Thanks in advance for your help.
PhyberApex
(Phyber Apex)
September 22, 2017, 1:46pm
2
You seem to have misunderstood the way this component works. You need 2 automations for an alarm to work.
The component works as follows.
Alarm is unarmed -> nothing happens.
Alarm gets armed (either home or away) -> pending for the pending_time -> Alarm is armed.
Alarm gets triggered -> pending for the trigger_time -> Alarm is triggered.
As you can see you need to separate your automation into two parts. One that does the triggering of the alarm and the seconds one which is the actual alarm (e.g. a siren).
Hope this helps.
~Cheers
pplucky
(Pplucky)
September 22, 2017, 2:04pm
3
Hello @PhyberApex .
First of all, thanks for taking the time to answer me.
Clear on the way the component is supposed to work, but my automations are separate, I just forgot to post also the arming one.
automation:
- alias: "Alarm arm pending"
platform: state
to: 'pending'
condition:
condition: state
state: 'pending'
ringtone_id: 10006
ringtone_vol: 4
delay: 2
- platform: state
to: 'on'
- platform: state
to: 'on'
condition:
condition: state
state: 'armed_away'
ringtone_id: 10004
ringtone_vol: 50
delay: 2
push:
badge: 5
category: "ALARM"
How does the automation know it should wait for the pending/trigger time?
Thanks again for your help.
PhyberApex
(Phyber Apex)
September 22, 2017, 2:08pm
4
In this case you need 3 automations. The time is between the state armed_(away/home),pending, triggered.
You are missing the automation for the triggered state.
- platform: state
to: 'on'
- platform: state
to: 'on'
condition:
condition: state
state: 'armed_away'
- alias: "Alarm triggered"
- platform: state
to: 'triggered'
ringtone_id: 10004
ringtone_vol: 50
delay: 2
push:
badge: 5
category: "ALARM"
This should do the trick.
~Cheers
pplucky
(Pplucky)
September 22, 2017, 2:33pm
5
After understanding the statuses of the alarm, using platform state and from/to statuses, I managed to control the alarm as I wanted to.
Thanks a lot, for your insights and ideas, @PhyberApex .
This community rocks!!!
