i have a switch far away. How can i manually connect this switch to the second to last switch in zigbee2 mqtt.
You can pair it through the device in the GUI, but Zigbee is not designed to make exclusive connections. If you are struggling with making the connection some router devices between the device and the coordinator usually helps.
