I’m trying to set up a new HA server to replace my old one, but I’m running into an issue with custom components…
Some of the support I need now appears to be in components to be installed from HACS. Problem: following the recommendation to install HA in a Docker container on my shared server, it has no Supervisor option. I tried to add the Supervisor, but the official install script fails. Apparently it’s possible to add HACS, but after reading 3 levels deep into the warnings (are you SURE you want to do this? check these mandatory boxes to affirm that you are a Linux and Home Assistant expert and you know how to read error logs), I decided not to attempt that if they expect it to mess up!
So let me ask this: I’ve had no problem downloading and installing custom components in the past with my old installation, so is there still some approved manual way of doing this for HACS components?
