I set up a generic thermostat for my electric convector to replace the automation I used so far (based on hour, gcal events and temperature).
It works, and I still use an automation for turning on and off the thermostat accordingly to hour and events, but now I need to override the automation and turn the thermostat on and off when needed.
My idea was to use a template switch, but it does not update its status based on thermostat status. I think it’s because the “on” status for the thermostat is actually “heat” and not “on”, but even with the conditional value for the template it does not work.
Here the code.
(climate.yaml)
- platform: generic_thermostat
heater: switch.bedroom
target_sensor: sensor.bedroom
min_temp: 16
max_temp: 21
ac_mode: False
target_temp: 17
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
initial_operation_mode: "off"
(template switch)
switches:
thermostat:
friendly_name: "Thermostat"
value_template: "{% if is_state('climate.bedroom.operation_mode', 'heat') %}on{% else %}off{% endif %}"
turn_on:
service: climate.turn_on
entity_id: climate.bedroom
turn_off:
service: climate.turn_off
(I tried both status and operation_mode, but the switch stays off )
Where I’m wrong?
