When triggering an automation manually in the GUI automation window (Configuration > Automation ) using the ‘TRIGGER’ label, are the conditions still checked or is the automation run regardless of conditions.
It skips straight to the action section of the automation.
I believe that conditions within the action section would be checked but cannot confirm as I don’t have any automations to test.
That would explain whilst testing the automation is wasn’t working as expected. Thanks
