I’ve tried several times to upgrade to 2020.12.1 in the gui but nothing happends. Now I tried doing it manually via ssh but I get an error.
Do anyone have any suggestions on how to fix this so I can upgrade?
➜ ~ pip3 install --upgrade homeassistant
Collecting homeassistant
Downloading homeassistant-2020.12.1-py3-none-any.whl (10.1 MB)
|████████████████████████████████| 10.1 MB 14 kB/s
Collecting requests==2.25.0
Downloading requests-2.25.0-py2.py3-none-any.whl (61 kB)
|████████████████████████████████| 61 kB 463 kB/s
Collecting astral==1.10.1
Downloading astral-1.10.1-py2.py3-none-any.whl (29 kB)
Collecting voluptuous-serialize==2.4.0
Downloading voluptuous_serialize-2.4.0-py3-none-any.whl (6.7 kB)
Requirement already satisfied, skipping upgrade: pip<20.3,>=8.0.3 in /usr/lib/python3.8/site-packages (from homeassistant) (20.1.1)
Requirement already satisfied, skipping upgrade: jinja2>=2.11.2 in /usr/lib/python3.8/site-packages (from homeassistant) (2.11.2)
Requirement already satisfied, skipping upgrade: pyyaml==5.3.1 in /usr/lib/python3.8/site-packages (from homeassistant) (5.3.1)
Collecting certifi>=2020.6.20
Downloading certifi-2020.12.5-py2.py3-none-any.whl (147 kB)
|████████████████████████████████| 147 kB 584 kB/s
Collecting ruamel.yaml==0.15.100
Downloading ruamel.yaml-0.15.100.tar.gz (318 kB)
|████████████████████████████████| 318 kB 513 kB/s
Collecting aiohttp==3.7.1
Downloading aiohttp-3.7.1.tar.gz (1.1 MB)
|████████████████████████████████| 1.1 MB 30 kB/s
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing wheel metadata ... done
Requirement already satisfied, skipping upgrade: async-timeout==3.0.1 in /usr/lib/python3.8/site-packages (from homeassistant) (3.0.1)
Collecting ciso8601==2.1.3
Downloading ciso8601-2.1.3.tar.gz (15 kB)
Collecting attrs==19.3.0
Downloading attrs-19.3.0-py2.py3-none-any.whl (39 kB)
Requirement already satisfied, skipping upgrade: pytz>=2020.1 in /usr/lib/python3.8/site-packages (from homeassistant) (2020.4)
Collecting bcrypt==3.1.7
Downloading bcrypt-3.1.7.tar.gz (42 kB)
|████████████████████████████████| 42 kB 123 kB/s
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /usr/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-fwt
ug8sp/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.8.0' whe
el 'cffi>=1.1; python_implementation != '"'"'PyPy'"'"''
cwd: None
Complete output (86 lines):
Collecting setuptools>=40.8.0
Using cached setuptools-51.0.0-py3-none-any.whl (785 kB)
Collecting wheel
Using cached wheel-0.36.2-py2.py3-none-any.whl (35 kB)
Collecting cffi>=1.1
Downloading cffi-1.14.4.tar.gz (471 kB)
Collecting pycparser
Downloading pycparser-2.20-py2.py3-none-any.whl (112 kB)
Using legacy setup.py install for cffi, since package 'wheel' is not installed.
Installing collected packages: setuptools, wheel, pycparser, cffi
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-4xzs1mj2/cffi/setup.py'"
'"'; __file__='"'"'/tmp/pip-install-4xzs1mj2/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().repl
ace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-p6_g8ipo/i
nstall-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-fwtug8sp/overlay --compile --install-headers /tmp/pi
p-build-env-fwtug8sp/overlay/include/python3.8/cffi
cwd: /tmp/pip-install-4xzs1mj2/cffi/
Complete output (68 lines):
Perhaps you should add the directory containing `libffi.pc'
to the PKG_CONFIG_PATH environment variable
Package 'libffi', required by 'virtual:world', not found
Package libffi was not found in the pkg-config search path.
unable to execute 'gcc': No such file or directory
No working compiler found, or bogus compiler options passed to
the compiler from Python's standard "distutils" module. See
the error messages above. Likely, the problem is not related
to CFFI but generic to the setup.py of any Python package that
tries to compile C code. (Hints: on OS/X 10.8, for errors about
-mno-fused-madd see http://stackoverflow.com/questions/22313407/
Otherwise, see https://wiki.python.org/moin/CompLangPython or
the IRC channel #python on irc.freenode.net.)
Trying to continue anyway. If you are trying to install CFFI from
a build done in a different context, you can ignore this warning.
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.8
creating build/lib.linux-armv7l-3.8/cffi
copying cffi/lock.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/api.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/__init__.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/recompiler.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/verifier.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/cparser.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/error.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/commontypes.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/model.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.8/cffi
copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.8/cffi
copying cffi/_embedding.h -> build/lib.linux-armv7l-3.8/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.8/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-armv7l-3.8
creating build/temp.linux-armv7l-3.8/c
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fomit-frame-pointer -g -fno-semantic-interposition -fomit-frame-pointer -g -fno-semantic-interposition -fomit-frame-pointer -g -fno-semantic-interposition -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.8 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.8/c/_cffi_backend.o
error: command 'gcc' failed with exit status 1
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-4xzs1mj2/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-4xzs1mj2/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-p6_g8ipo/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-fwtug8sp/overlay --compile --install-headers /tmp/pip-build-env-fwtug8sp/overlay/include/python3.8/cffi Check the logs for full command output.
ERROR: Command errored out with exit status 1: /usr/bin/python3 /usr/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-fwtug8sp/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.8.0' wheel 'cffi>=1.1; python_implementation != '"'"'PyPy'"'"'' Check the logs for full command output.
*1 [zsh] Sat 12-19 23:07
