Manually change attribute of Fronius Ohmpilot with button
Is there a way how to manually (with a button on dashboard) change status of attribute for sensor?
Fronius Ohmpilot has 5 attributes.
(up_and_running, keep_minimum_temperature, legionella_protection, critical_fault, fault, boost_mode)
The "boost_mode"does a thing where the ohmpilot send full power to the immersion heater whether there is surplus of energy from PV or not.
I need to be able to manually set this boost mode by a button on dashboard.
When I tried create automation / helper I am not able to choose Ohmpiot.sprava_stavu as I guess it was mentioned be just for reading not writing.
I was also thinking of getting an ohmplit but wasnt sure what functionality is provided since the official documentation doesnt state any setable values:
Ohmpilot
Detailed information about energy, power, and temperature of your Ohmpilots. Updated every minute.
Since im planning to implement a feature which is a like yours Im also interested if thats possible.
Hope this gets more attention since I couldnt gind anything related to this wxcept your post
The API used in the Fronius integration is purely read-only.
Maybe Modbus can be used to write things to Fronius devices. Have a look at the devices manual and Modbus register tables if there are any hints.
I was able to find a workaround.
I created button and calling restful command:
rest_command:
	setboost:
	url: ‘http://ipofdevice/setboost.cgi'
	method: “get”
With the first press it enables Boost Mode, with second it disable Boost. With the rest command it also works if you call the service from different location.
hello,
i’m looking for the same, can you give me more information on how you’ve solved it?
Thank you and have yourself a wonderful evening.
Pascal
Hi, I have created buttons to control the ohmpilot using the RESTCommand but the time variables are not received. How can I solve it?
http://192.168.88.229/set.cgi?name=Ohmpilot&H1Auto=automatic&tempInst=on&legCyc=0&maxTempUsed=on&maxTempCyc=55&tempUsed=on&chbxtime1=on&ontime1=17%3A00&offtime1=20%3A00&temp1=48&chbxtime2=on&ontime2=05%3A30&offtime2=06%3A30&temp2=51&H2Ph=aus&H2Power=0&H2ThModeOn=Einspeisung&H2ThOn=4000&H2ThModeOff=Einspeisung&H2ThOff=0"
Hi there. I have a new Ohmpilot and am sad about the limitations.
I would like to have an easy possibility to enable or disable it or to limit its power when the water is warm enough and I would rather charge my car using evcc. However, the integration can only read values.
A solution could be to set the „max temperature“ to a low value to disable the ohmpilot completely or to limit the watt power of the ohmpilot to a low value to charge the car in parallel. I can do this via the ohmpilot web interface but would rather do it directly from home assistant using a rest command. Is that possible? How can I achieve this? Thank you so much for your help
