Manually created scene not visible in Node-Red
Hi all,
I finally got around to fitting some LEDs, using WLED, over the garage door yesterday and created a new flow to automate them, nothing fancy just on at sunset and off at sunrise.
To make sure that they turn on white at 20% I manually created a scene in HA, which works great when I manually activate it.
However, when I have come to use this scene in NR it doesn’t appear in the auto-populated list. :confused:
It appears in my Entities.
Can anyone tell me what I’ve done wrong please? Will manually typing scene.garage_door_led as the Entity Id work?
In case the flow itself will help
        "id": "d03855c3.914c08",
        "type": "comment",
        "z": "65afea36.f08f24",
        "name": "At sunset turn on Garage door LED and off at sunrise",
        "info": "",
        "x": 220,
        "y": 1080,
        "wires": []
        "id": "e5e4ba63.b11e58",
        "type": "bigtimer",
        "outtopic": "",
        "outpayload1": "",
        "outpayload2": "",
        "name": "Big Timer",
        "comment": "",
        "lat": "90",
        "lon": "-135",
        "starttime": "5004",
        "endtime": "5003",
        "starttime2": "0",
        "endtime2": "0",
        "startoff": 0,
        "endoff": "0",
        "startoff2": 0,
        "endoff2": 0,
        "offs": 0,
        "outtext1": "On",
        "outtext2": "Off",
        "timeout": 1440,
        "sun": true,
        "mon": true,
        "tue": true,
        "wed": true,
        "thu": true,
        "fri": true,
        "sat": true,
        "jan": true,
        "feb": true,
        "mar": true,
        "apr": true,
        "may": true,
        "jun": true,
        "jul": true,
        "aug": true,
        "sep": true,
        "oct": true,
        "nov": true,
        "dec": true,
        "day1": 0,
        "month1": 0,
        "day2": 0,
        "month2": 0,
        "day3": 0,
        "month3": 0,
        "day4": 0,
        "month4": 0,
        "day5": 0,
        "month5": 0,
        "day6": 0,
        "month6": 0,
        "day7": 0,
        "month7": 0,
        "day8": 0,
        "month8": 0,
        "day9": 0,
        "month9": 0,
        "day10": 0,
        "month10": 0,
        "day11": 0,
        "month11": 0,
        "day12": 0,
        "month12": 0,
        "d1": 0,
        "w1": 0,
        "d2": 0,
        "w2": 0,
        "d3": 0,
        "w3": 0,
        "d4": 0,
        "w4": 0,
        "d5": 0,
        "w5": 0,
        "d6": 0,
        "w6": 0,
        "xday1": 0,
        "xmonth1": 0,
        "xday2": 0,
        "xmonth2": 0,
        "xday3": 0,
        "xmonth3": 0,
        "xday4": 0,
        "xmonth4": 0,
        "xday5": 0,
        "xmonth5": 0,
        "xday6": 0,
        "xmonth6": 0,
        "xd1": 0,
        "xw1": 0,
        "xd2": 0,
        "xw2": 0,
        "xd3": 0,
        "xw3": 0,
        "xd4": 0,
        "xw4": 0,
        "xd5": 0,
        "xw5": 0,
        "xd6": 0,
        "xw6": 0,
        "suspend": false,
        "random": false,
        "randon1": false,
        "randoff1": false,
        "randon2": false,
        "randoff2": false,
        "repeat": true,
        "atstart": true,
        "odd": false,
        "even": false,
        "x": 80,
        "y": 1140,
        "wires": [
                "426c7acb.5e5cc4"
        "id": "823bc7c.f66e538",
        "type": "api-call-service",
        "name": "Turn on lights",
        "server": "7dbc1ed6.c0f6e",
        "version": 1,
        "debugenabled": false,
        "service_domain": "scene",
        "service": "turn_on",
        "entityId": "scene.garage_door_led",
        "data": "",
        "dataType": "json",
        "mergecontext": "",
        "output_location": "",
        "output_location_type": "none",
        "mustacheAltTags": false,
        "x": 600,
        "y": 1120,
        "wires": [
        "id": "2f1fb186.82633e",
        "name": "Turn off lights",
        "version": 1,
        "service_domain": "light",
        "service": "turn_off",
        "entityId": "light.garage_door_led",
        "data": "",
        "dataType": "json",
        "mergecontext": "",
        "x": 600,
        "y": 1180,
        "wires": [
        "id": "426c7acb.5e5cc4",
        "type": "switch",
        "name": "",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "On",
                "vt": "str"
                "t": "eq",
                "v": "Off",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 210,
        "y": 1140,
        "wires": [
                "12d0af00.33d581"
                "b15a45c4.1c1908"
        "id": "12d0af00.33d581",
        "type": "api-current-state",
        "name": "Are the lights already on?",
        "version": 1,
        "outputs": 2,
        "halt_if": "on",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "override_topic": false,
        "entity_id": "light.garage_door_led",
        "state_type": "str",
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "blockInputOverrides": false,
        "x": 390,
        "y": 1120,
        "wires": [
                "823bc7c.f66e538"
        "id": "b15a45c4.1c1908",
        "name": "Are the lights already off?",
        "version": 1,
        "outputs": 2,
        "halt_if": "off",
        "x": 390,
        "y": 1180,
        "wires": [
                "2f1fb186.82633e"
        "id": "7dbc1ed6.c0f6e",
        "type": "server",
        "name": "Home Assistant",
        "addon": true
Caching issue.
https://zachowj.github.io/node-red-contrib-home-assistant-websocket/FAQ.html#entities-not-showing-in-the-autocomplete-dropdown
@Kermit, thank you. I’m sure you’re omnipresent lol.
I’ll give it a restart, disappointed in myself that I didn’t think to do that before posting. :man_facepalming:t3: I’ll leave this up, so others can revel in my stupidity.
