HI. After an upgrade last month I have not been able to get HA to run. I am not able to connect to the Web UI. I pulled the SD card and retrieved the log and found a message stating “[pymyq.api] Device update failed; trying again in 1 seconds” over and over. I am hoping that I can just disable this integration but I am not sure the best way to do it. I installed the integration using the UI if that makes a difference.
At the moment it seems like I can only access the file system by using the SD plugged into my windows machine. To be honest I am not sure if SSH is enabled as I was trying to do as much as possible through the UI.
