Manually entering values from currently not supported sensors?
I am interested in streaming sensor data from sports sensors, EEG devices, Activity tracker into Home Assistant. There are several options to this. But I would also like to enter data manually, for instance sleep duration, weight from devices which are not supported yet. How can I enter manually values from a currently from HA unsupported sensor to HA, to have all data in the same database with the sensor data from supported devices?
Thanks tom I.
Is there an example which can be modified to make out of it an application which allows to enter for instance sleep duration manually into Home Assistant?
