Hi there,
I want to be able to input a manual water reading into Home Assistant and for it to show me how much I’m using each month (I’m aiming to read the meter reading manually each month).
I’ve followed the guides - but am a bit stuck on what next.
- I’ve setup a water meter input number in helpers:
- Initial: null
- Editable: true
- Min: 0
- Max: 99999
- Step: 1
- Mode: Box
- Fiendly Name: Water Meter
- Then I’ve setup a sensor in the config.yaml as follows:
sensors:
water_usage:
friendly_name: "Water Usage"
unit_of_measurement: 'm³'
value_template: "{{ (states('input_number.water_meter_3')|float - states('input_number.water_meter_3_previous')|float) | round(2) }}"
Could you advise on what next (I want to be able to show this in my dashboard so I can input the number manually and it shows a monthly graph of water usage).
Tracking spend (as much as I’d like to do) is a bit more tricky as it’s a pretty complex setup in the UK based on standing charges, usage, sewage and normal water etc.
Thanks!
