Manufacture and sell Home Assistant Yellow Devices
Can I use the Home Assistant Yellow open source hardware details shared on Github to manufacture and sell it in market (online/offline)? Do I need to pay any royalty OR follow any instructions? Any feedback would be appreciated.
You may redistribute and modify this source and make products using it under
the terms of the CERN-OHL-S v2 (cern_ohl_s_v2.txt in this repository).
https://github.com/NabuCasa/yellow/blob/6891c93ca07129a19bda0e689223379b113b8b85/LICENSE.md
Full licence details:
https://spdx.org/licenses/CERN-OHL-S-2.0.html
Yellow is based on a RPi which uses more then 10 year old lithography (22nm) and is well known to have a high idle consumption of 3-4 watts.
If you want to really manufacture hardware in 2023/2024 please don’t use such stone aged designs but go with something a little fresher in terms of being much more efficient.
Check out the home assistant green and specially the RK3566 that it is build around! (talking about 1 watt idle with ethernet connected!)
Thanks Tom!
By any way is Home Assistant Green hardware (Home Assistant Green - Home Assistant) is also open source and can be manufactured to sell in market as per CERN-OHL-S V2 license?
Makes Sense. Thanks for the inputs.
I don’t think so. I can’t find any hardware files on github.
