ok so ive tried to get the manything switch working using the config on the website https://home-assistant.io/components/ifttt.manything/
However when i just copy and paste that in, note that there is nothing else in the automation section, and i restart the Home Assistant, it doesn’t start again. I made a few changes to the formatting and i can get it to start however it then says all of my devices are not home. The ones it checks the MAC address for in the router. When in fact i know they are connected. Any help with this? Ill attach my config for you to look at. This is with the formatting changed so it works a little better. (sorry i had to zip the file, couldnt upload just the .yaml)
