The latest release is now v0.10.0 which fixes missing pictures, tap actions not working for icons etc.
Is it now possible to have a custom tap action? For example tapping on an icon does not open the entity but a url instead? Thanks again!
Guess you need to register a FR with a detailed description on Github.
Not possible yet, however should not be too hard to add.
You can add your insights and comments to this Github Issue: Custom tap actions · Issue #19 · nathan-gs/ha-map-card · GitHub
Since v1.4.0 it’s now possible to define custom tap actions.
Just discovered this and really appreciate it!
Does anyone else have an issue with the history always showing an extra line connecting a person entity’s latest coordinates to home? Maybe it’s just me misconfiguring something.
Post an image, the issue is unclear.
It’s my bad It resolved itself after the history time cleared. Must be just an issue when I first start the history.
Why does it take 30 seconds or longer to initially display the map? After the initial load, it’s very zippy. Is there some thing I can do to speed it up?
The history feature of this card makes it incredibly useful, thanks for the work on this!
I live on a boat, and I have zones for where home (the boat) and the anchor location are. I’m updating the zones via various automations.
When I drop the anchor and let out chain, I set the radius of the anchor zone. Then I also set a larger radius for the anchor alarm (if the boat goes outside of the outer radius, HA shouts at me over all of my devices).
Having the visualization of the inner and outer circles is useful, as is the visualization of the boat location over time.
Is there a way to draw the inner and outer circles on your map card so that I can just have a single card on my dashboard?
Thanks!
type: custom:map-card
history_start: 24 hours ago
entities:
- entity: zone.home
history_start: 48 hours ago
display: icon
history_show_lines: true
history_show_dots: false
color: blue
- entity: zone.anchor_location
history_start: 5 seconds ago
display: icon
history_show_lines: false
I would say this is a good FR:
add a Boolean flag to show circle for a zone; may be defined per entity; meaningful only for zone entities.
Also, similarly a circle may be shown for ANY entity:
- For zones - radius is equal to a zone’s radius.
- For other entities - radius is equal to a GPS accuracy (if present).
Does anyone know the tile_layer_url that I can use that is the same as the default HA card?
What is the right configuration for OpenWeather Weather Maps 2.0?
Here is an example config I’m using (API keys redacted):
focus_entity: zone.home
zoom: 6
card_size: 10
entities:
- entity: zone.home
display: icon
tile_layers:
- url: >-
https://maps.openweathermap.org/maps/2.0/weather/1h/PR0/{z}/{x}/{y}?appid=<I have replaced this with my actual API key>
options:
attribution: <a href="https://openweathermap.org/">OpenWeatherMap</a>
apikey: <I have replaced this with my actual API key>
It’s not displaying anything and I’ve tried a few different values. Does the attribution key need to be altered in some way?
Assuming the rest of the url is correct replace ?appid=<I have replaced this with my actual API key>
with ?appid={apikey}
. As per https://nathan.gs/2024/02/25/ha-map-card-displaying-weather-and-other-tilelayers/#creating-the-map
To be sure we’re working toward the same goal…I’m trying to get Map 2.0 (not 1.0) working.
The 1.0 config seems to work with the {apikey} placeholder (as you mentioned) or explicitly replacing it with the actual api key (as I had it) since apikey: is specified on the third line.
For 2.0 (see link I posted above) I tried the same config as what you posted (that’s where I got it from initially) but replaced the 1.0 URL with the 2.0 URL. So, I’m asking if something else (e.g. attribution) also needs adjustment to get 2.0 to work. If so, what are those adjustments?
It would be cool to have an option to simply put an icon instead of a picture, when the sensor do not include it
For example on the map I see the label:
If I click on it. I have an icon, but into the attributes there is no icon attribute.
Would be nice, just to use the same logic like the detail dialog and/or give an option on the entity section to override the icon
EDIT: FR is open
Any option like the default map card to refresh so it moves as the entity moves?
There is, like this.
entities:
- entity: <your_entity>
display: icon
picture: /local/icons/icon.png
