Map Card and GPS
Hi all,
I use Home Assistant in my van and want to display my current location on the Map Card.
I get the current Latitude and Longitude via command_line from my GPS router and it is already displayed correctly in degrees.
- platform: command_line
    name: GPS Breitengrad
    command: "ssh [email protected] 'gpsctl -i'"
    unit_of_measurement: "°"
    scan_interval: 3
    command_timeout: 5
    command: "ssh [email protected] 'gpsctl -a'"
    unit_of_measurement: "m"
    scan_interval: 3
    command_timeout: 5
But how can I get these Coordinates displayed in the Map Card?
Peter
Maybe read this thread ( Combine GPS sensors and show them on the map, with or without device tracker? - Configuration - Home Assistant Community (home-assistant.io)) for a similar question.
Thanks for your answer, but it didn’t help me. I tried following automation.
  - id: update_gps_position
    alias: gps_status_x
    alias: Update GPS position
      platform: state
      entity_id:
        - sensor.gps_breitengrad
        - sensor.gps_langengrad
    condition: []
      - service: device_tracker.see
        data_template:
          mac: FF:FF:FF:FF:FF:F7
          dev_id: campergps
          host_name: camper
          source_type: gps
          gps:
            - "{{ states('sensor.gps_breitengrad') }}"
            - "{{ states('sensor.gps_langengrad') }}"
and it is shown as follows:
But when I try to use it, nothing is shown in map:
Do I have to define an device first? But where, the
Solved it! :slight_smile:
I had to add
device_tracker:
in configuration.yaml
Thanks for your help
Hi Proflan,
did you also use that Automation you shared? (I mean combine with the “device_tracker” config?
  • Guus
