Map doesnt show with Fire HD 10 an Fully Kiosk
Hello, i have the problem that my map in the sidebar doesnt show up. I can see my location but no map is shown. Also the rainmap card doesnt show up. Can somebody help me?
On the phoe all works fine.
Thanks for your help.
Hi, welcome in the forum!
You can change the contents from the sidebar by going to the bottom of it where you find your user/profile settings and under ā€˜Browser Settings’ → ā€˜Change the order and hide items from the sidebar’
Check if the map item is marked to be hidden.
Thanks for the tip, but thats not my problem. you can see on the pictures that the map doesnt show up? On the mobilephone it works. I cut the internet connection to the fire hd but it should load the map because it goes over the home adsistant pc? is that right?
Did you try clearing the app cache?
Yes but it doesnt help.
Is your device up-to-date?
Which browser is installed and is it updated?
yes its 2 days old. fully kiosk is running on it.
I have no experience with FK.
Do you know which browser is installed on the device and if you can add another one?
Maybe switching browser might change things…
How did you ā€œcut off the internet connectionā€? > Firewall?
yes via the router. but should it be not a thing because the whole ā€œworkā€ should do the HA Server/PC? And this have normal internet connectivity
Wait: are you trying to use the device without internet connection?
I’ll guess that should not be a problem as a Fire HD client :wink:
Simple test is to open internet connection for the device
yes everything works without the internet. its just a dumb display wich streams my HA Dashboard in my w lan. The fire hd 10 is not so good with internet connection :smile:.
Tested it, have the same problem.
You have to figure out which route is used for open street map and configure the firewall
So it seems the map is pulled from the internet or needs an active internet connection?
Yes (my post needs 10 caracters :wink: )
Yes you are right. with internet it works. But how can i do, that the fire hd dont ativate the ota updates from amazon and work with the map? Is there a way around?
I don’t think you can with a standard setup, either you give the device internet access to be able to get that map and thus get updates from Amazon, or none of that.
You could start to use Pi-Hole (or similar) to block Amazon for the tablet or your whole LAN.
Are there any ā€œofflineā€ weather maps? I think its a problem to aktivate the internet for the Fire HD because they are performing OTA Updates and there is the risk, that the FULLY KIOSK doesnt work anymore. Im wondering why the Tablet needs internet because it should only stream the images from the core HA system.
The integrated map is not showing the weather.
But yes, you can add weather integrations that are pulled from your HA system: home-assistant integrations → weather
