After update HA to version 0.56.2 and configure owntracks http, i see that in fronted of HA, is not showed the map option.
Here logs of version 0.56.2:
2017-10-28 12:03:47 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=148 from 2017-10-28 10:02:27.484728)
2017-10-28 12:03:53 ERROR (MainThread) [homeassistant.components.binary_sensor] Error while setting up platform netatmo
File "/usr/src/app/homeassistant/helpers/entity_component.py", line 170, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/src/app/homeassistant/components/binary_sensor/netatmo.py", line 75, in setup_platform
if not data.get_camera_names():
File "/usr/src/app/homeassistant/components/netatmo.py", line 84, in get_camera_names
self.update()
File "/usr/src/app/homeassistant/util/__init__.py", line 306, in wrapper
result = method(*args, **kwargs)
File "/usr/src/app/homeassistant/components/netatmo.py", line 115, in update
self.camera_data = lnetatmo.CameraData(self.auth, size=100)
File "/usr/local/lib/python3.6/site-packages/smart_home/Camera.py", line 78, in __init__
self.default_camera = list(self.cameras[self.default_home].values())[0]
IndexError: list index out of range
2017-10-28 12:03:53 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo
return fut.result()
File "/usr/src/app/homeassistant/components/climate/netatmo.py", line 47, in setup_platform
for module_name in data.get_module_names():
File "/usr/src/app/homeassistant/components/climate/netatmo.py", line 161, in get_module_names
for module in self.thermostatdata.modules[self.device].values():
KeyError: 'relay_T'
2017-10-28 12:03:59 ERROR (MainThread) [homeassistant.components.camera] Error while setting up platform netatmo
return fut.result()
File "/usr/src/app/homeassistant/components/camera/netatmo.py", line 42, in setup_platform
for camera_name in data.get_camera_names():
self.update()
2017-10-28 12:03:59 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2017-10-28 12:03:59 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2017-10-28 12:04:09 WARNING (SyncWorker_5) [netdisco.ssdp] Found malformed XML at http://192.168.1.99:9080: status=ok
I returned to version 0.53.0 without changing anything, and the map now is shown.
Here are logs of version 0.53.0:
2017-10-28 11:55:28 ERROR (MainThread) [homeassistant.loader] Unable to find component device_tracker.owntracks_http
2017-10-28 11:55:35 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo
File "/usr/src/app/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform
return fut.result()
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run
KeyError: 'relay_T'
2017-10-28 11:55:36 ERROR (MainThread) [homeassistant.components.camera] Error while setting up platform netatmo
return fut.result()
self.update()
2017-10-28 11:55:36 ERROR (MainThread) [homeassistant.components.binary_sensor] Error while setting up platform netatmo
return fut.result()
File "/usr/src/app/homeassistant/components/binary_sensor/netatmo.py", line 76, in setup_platform
self.update()
2017-10-28 11:55:39 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2017-10-28 11:56:02 WARNING (SyncWorker_15) [netdisco.ssdp] Found malformed XML at http://192.168.1.99:9080: status=ok
