Mapping HA / MQTT on Python based HAVC system
HA appears as a very neat way to control the HVAC system I am building. The HVAC includes a classic CV, a heatpump, multi-group floorheating, radiators etc and of course a bunch of sensors. The control over these components is done using on a Rasp Pi Pico with drivers / hw control written in MicroPython. Interaction with HA is done using Mosquitto MQTT.
getting acqainted with HA have brought me to get single sensor readings from the controller, via MQTT to HA and visualize it on a dashboard. The ultimate situation is that multiple sensors broadcast their value - upon change - against a single MQTT topic: heating/sensor_data. In Python terms, I would send a “dictionary_of dictionaries”. Like: { {sensor_a: data_a}, {sensor_b: data_B}}. In doing so, HA thus needs to extract the sensor_id and the sensor’s data from that topic. And here is where I get confused how to do that. In the HA MQTT section, reference is made to two declarations I may need: “json_attributes_topic” and “json_attributes_template” to allow HA to extract sensordata from my “dict_of-dicts” as published.
Setting YAML up as follows however fails:
mqtt:
    - json_attributes_topic: "heating/sensor_data"
    - json_attributes_template:
        "sl_verd": <string>,
        "sl_cv_aanv": <string>,
        "sl_cv_ret": <string>
The YAML conf checker thinks this is ok but it fails on the reload. I appear to miss (do not understand) the way this is supposed to work. Any clarification / guidance to achieve my objective is highly appreciate. THX !
A Device can have many Entities. Sensors are Entities.
Thank you for your input. However, I do not see how that solves my challenge. Sorry for that. The project I am working is the first HA activity for me that goes beyond installing a predefined integration where the focus is more on organizing a dashboard. For a novice, HA is (over)loaded with options, making virtually everthing possible but little very simple. Again, thanks.
Does this help?
thank you again; helpful ! Also learned that rather than using mqtt explorer, HA allows through configure mqtt to have a direct look at the topic-data. That helped to solve the immediate problem that I had of data not showing up in the dashboard, dispite what I thought was the correct json format. I had to wrap sensor-names in an extra set of quotes in Python before shipping the data to mqtt.
