Mapping JSON Output from True to Closed
Hi I have a door sensor that outputs as True or false. I am trying to remap the output so instead of true it outputs this as CLOSED and false as OPEN. This is aqara window/door sensor using the zigbee2mqtt gateway.
Sensor info in configuration.yaml
  • platform: “mqtt”
    state_topic: “zigbee2mqtt/0x00300d000104baba”
    availability_topic: “zigbee2mqtt/bridge/state”
    payload_on: false
    payload_off: true
    value_template: “{{ value_json.contact}}”
    json_attributes:
    • “battery”
  sensors:
    the_front_door:
      friendly_name: "Jamos' Front Door"
      entity_id:
        - sensor.front_door
      value_template: >-
        {% if is_state('sensor.front_door', 'true') %}
          Closed
        {% else %}
          Open
        {% endif %}
Use sensor.the_front_door to display the mapped version.
Thanks Florian, That solved it. Much appreciated.
