Mapping not allowed in config/configuration.yaml
Hi!
I´m new in this with working with HA. its really interested, but I get into some problem even if I try to follow some instructions on internet. some installation works good, but now I get inte to a problem that I which that someone can help me with.
I have installed portioner, influxdb, Grafana, watchtower, pihole and now latest configurator.
But not I got into problem when I check the configuration.
I got the error:
Error loading /config/configuration.yaml: mapping values are not allowed here in “/config/configuration.yaml”, line 18, column 10
my configuration.yaml looks like this
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
influxdb:
host: 192.168.0.86
panel_iframe:
configurator
title: "Configurator"
url: 'http://192.168.0.86:3218'
icon: ndi:wrench
graf:
title: 'Grafena'
url: http://192.168.0.86:3000
icon: mdi:chart-bar-stacked
Where do I have the problem? thanks in advanced / Markus
Please see the sticky post for how to correctly mark code blocks.
The errors suggests the problem relates to indenting, or lack of, but we can’t tell.
sorry for the bad input. first time here.
Maybe this is better for show the codes.
default_config:
# Text to speech
tts:
influxdb:
  host: 192.168.0.86
panel_iframe:
  configurator
    icon: ndi:wrench
  graf:
    title: 'Grafena'
I did at least find out what the problem was. missed the : behind configurator. that solved my issue.
HI guys,
I have run into an issue now too,
automation.back_room_flic_double_push# Loads default set of integrations. Do not remove.
default_config:
Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
DO NOT RENAME THIS FILE TO CONFIGURATION.YAML! YOU WILL BREAK YOUR CONFIG IF YOU DO SO!
INSTEAD, COPY THIS CODE WITHIN YOUR OWN SECRETS.YAML
Error
"end of the stream or a document separator is expected (2:15)
1 | automation.back_room_flic_double_push# Loads d ...
2 | default_config:
3 |
4 | # Load frontend themes from the themes folder"
in "/config/configuration.yaml", line 2, column 15
I cant see what ive messed up with
Please format your post
Logger: homeassistant.components.homeassistant
Source: components/homeassistant/init.py:338
Integration: Home Assistant Core Integration (documentation, issues)
First occurred: 8:22:22 PM (2 occurrences)
Last logged: 8:49:30 PM
The system cannot reload because the configuration is not valid: Error loading /config/configuration.yaml: mapping values are not allowed here in “/config/configuration.yaml”, line 2, column 15
default_config:
frontend:
# DO NOT RENAME THIS FILE TO CONFIGURATION.YAML! YOU WILL BREAK YOUR CONFIG IF YOU DO SO!
# INSTEAD, COPY THIS CODE WITHIN YOUR OWN SECRETS.YAML
That first line is wrong and shouldn’t be there.
got it all sorted now, Thanks,
just having at issue trying to ger something else back up and running
