Just tried my frist steps with Lovelace and for some reason I keep getting the following error:
mapping values are not allowed here in “/home/homeassistant/.homeassistant/ui-lovelace.yaml”, line 30, column 17
The line producing that error is: icon: mdi:temperature-celsius
All other Icon lines produce the same error. However I already tried a name: instead of icon:, still the same problem.
Any ideas?
title: Title
# Specify a tab icon if you want the view tab to be an icon.
- icon: mdi:home-assistant
# Title of the view. Will be used as the tooltip for tab icon
title: Home
theme: dark-mode
cards:
# Entities card will take a list of entities and show their state.
- type: entities
# Title of the entities card
title: Lichter
# The entities here will be shown in the same order as specified.
# Each entry is an entity ID or a map with extra options.
entities:
- light.wohnzimmerlicht_boden
- light.wohnzimmerlicht_decke
- light.schlafzimmerlicht
- light.esszimmerlicht_2
- light.gastezimmerlicht_2
- switch.osramplug1
# The markdown card will render markdown text.
- type: glance
title: Wohnzimmerklima
show_name: false
entities:
- sensor.bme680_temperature
- sensor.bme680_iaq
icon: mdi:chart-bubble
- sensor.bme680_humidity
icon: mdi:water-percent
- sensor.bme680_pressure
icon: mdi:balloon
If you put the title line first, then the icon line?
So something like this:
title: Home
- title: default_view
icon: mdi:home
and see if the error goes.
I notice all the icons have underscores or dashes, do you still get the error if you use icons without either of those. Also I didn’t think the mdi icons name convention used undescores, thought they were all dashes.
The error is produced further down in line 30, the title was working fine. Also initially I didn’t have any icons, but names, but this produced the same error. So the error is in all of those lines respectively:
- type: glance
show_name: false
entities:
icon: mdi:temperature-celsius # <--- Error is produced here. name: Temperature produces the same error
Actually I suspect the Lovelace yaml is going to do away with groups and customize but the docs are a bit light on. Will be nice when Lovelace is out of beta as then I think it will be more clear. 0.84 I think Lovelace will be the default.
Reminds me as well… the other reason to use Lovelace instead of customize is that when you edit Lovelace you don’t need to restart home assistant to see the changes… that is a big benefit of Lovelace.
