Hi all
I have Home Assistant running in a docker container via docker-compose on my NUC 7i5. I am having some issues mapping my Aeotec z-wave dongle to be accessible by my Home assistant instance.
I have used the following docker-compose (following the guide from https://www.smarthomebeginner.com/docker-home-media-server-2018-basic/)
homeassistant:
container_name: homeassistant
restart: always
image: homeassistant/home-assistant
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
- /dev/ttyUSB1:/dev/ttyUSB1
- /dev/ttyACM0:/dev/ttyACM0
volumes:
- ${USERDIR}/docker/homeassistant:/config
- /etc/localtime:/etc/localtime:ro
- ${USERDIR}/docker/shared:/shared
ports:
- "8123:8123"
privileged: true
environment:
- PUID=${PUID}
- PGID=${PGID}
- TZ=${TZ}
where the PUID is the user ID of my Ubuntu log in, and the PGID is the docker group
I have run
$ ls -ltr /dev/tty*|tail -n 1
and determined that my Aeotec Dongle is plugged into
/dev/ttyACM0
which is one of the devices specified in the docker compose file.
my configuration file for home assistant has the following for the z-wave component
zwave:
usb_path: /dev/ttyACM0
When I check my configuration - it all checks out, and when I reload home assistant I get
INVALID CONFIG
The following components and platforms could not be set up:
zwave
Please check your config.
When I look at my Home assistant logs, I get the following
Error during setup of component zwave
File "/usr/local/lib/python3.6/site-packages/openzwave/option.py", line 78, in __init__
raise ZWaveException(u"Can't find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: "Zwave Generic Exception : Can't find device /dev/ttyACM0 : ['NoneType: None\\n']"
File "/usr/src/app/homeassistant/setup.py", line 145, in _async_setup_component
hass, processed_config)
File "/usr/src/app/homeassistant/components/zwave/__init__.py", line 244, in async_setup
config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
File "/usr/local/lib/python3.6/site-packages/openzwave/option.py", line 81, in __init__
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : [\'Traceback (most recent call last):\\n\', \' File "/usr/local/lib/python3.6/site-packages/openzwave/option.py", line 78, in __init__\\n raise ZWaveException(u"Can\\\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\\n\', \'openzwave.object.ZWaveException: "Zwave Generic Exception : Can\\\'t find device /dev/ttyACM0 : [\\\'NoneType: None\\\\\\\\n\\\']"\\n\']'
It looks like it can’t find the device despite being pointed in the right direction
I have run
sudo usermod -a -G dialout homeassistant
My installation is on a brand new Ubuntu 18.04 LTS running on the NUC. It only has the one user, which I used in the place of “homeassistant”.
As I mentioned I followed the guide https://www.smarthomebeginner.com/docker-home-media-server-2018-basic/. I have noticed that to edit the files which is saved in the /~/Home/docker/homeassistant folder I need to log in as root - is this the problem?
I must admit I am relatively new to Linux, and the main issue I have been experience relate to user permissions.
Any suggestions on where I am going wrong?
