Hey there,
after upgrading core to 2024.9 / 2024.9.1, I get a recorder error, because the database migration fails. The error mentioned is, that during the update of foreogn keys, the connection was lost. After I increased the timeout for sessions and statents to 24 hours, I still got the error.
I linked the recorder to a mariadb on a different server, but this runs for a year without issues. So I guess this is related to any change in the update. Home assistant is installed on a RPI4.
My curre t versions
- Core 2024.9.1
- Supervisor 2024.08.0
- Operating System 13.1
- Frontend 20240906.0
This is the first error
Could not update foreign options in states table
Logger: homeassistant.components.recorder.migration
Source: components/recorder/migration.py:753
integration: Recorder (documentation, issues)
First occurred: 6:13:34 AM (1 occurrences)
Last logged: 6:13:34 AM
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1967, in _exec_single_context
self.dialect.do_execute(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/default.py", line 924, in do_execute
cursor.execute(statement, parameters)
File "/usr/local/lib/python3.12/site-packages/MySQLdb/cursors.py", line 179, in execute
res = self._query(mogrified_query)
File "/usr/local/lib/python3.12/site-packages/MySQLdb/cursors.py", line 330, in _query
db.query(q)
File "/usr/local/lib/python3.12/site-packages/MySQLdb/connections.py", line 261, in query
_mysql.connection.query(self, query)
MySQLdb.OperationalError: (2013, 'Lost connection to server during query')
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 753, in _add_constraint
connection.execute(add_constraint)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1418, in execute
return meth(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/sql/ddl.py", line 180, in _execute_on_connection
return connection._execute_ddl(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1529, in _execute_ddl
ret = self._execute_context(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1846, in _execute_context
return self._exec_single_context(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1986, in _exec_single_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2353, in _handle_dbapi_exception
raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
db.query(q)
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (2013, 'Lost connection to server during query')
[SQL: ALTER TABLE states ADD FOREIGN KEY(old_state_id) REFERENCES states (state_id)]
(Background on this error at: https://sqlalche.me/e/20/e3q8)
This is the second one
Logger: homeassistant.helpers.recorder
Source: helpers/recorder.py:101
Error executing query
db.query(q)
File "/usr/src/homeassistant/homeassistant/helpers/recorder.py", line 101, in session_scope
yield session
return meth(
db.query(q)
and the last one
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:981
Database error during schema migration
db.query(q)
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 981, in _migrate_schema
new_schema_status = migrator(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 334, in migrate_schema_live
schema_status = _migrate_schema(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 300, in _migrate_schema
_apply_update(instance, hass, engine, session_maker, new_version, start_version)
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 703, in wrapper
job(instance, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 883, in _apply_update
migrator_cls(instance, hass, engine, session_maker, old_version).apply_update()
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 929, in apply_update
self._apply_update()
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 1761, in _apply_update
_restore_foreign_key_constraints(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 721, in _restore_foreign_key_constraints
_add_constraint(session_maker, add_constraint, table, column)
return meth(
db.query(q)
