Hi there,
I’m trying to get a MariaDB SQL database running next to docker where I can record my events into.
At the moment I’m using the following docker compose for the database:
Here is the docker compose:
The *** passwords here are for test purposes the same
mariadb:
container_name: mariadb
image: yobasystems/alpine-mariadb
restart: always
environment:
MYSQL_ROOT_PASSWORD: ***
MYSQL_DATABASE: ha_database
MYSQL_USER: homeassistant
MYSQL_PASSWORD: ***
PUID: 1000
PGID: 1000
volumes:
- /opt/mariadb:/etc/mysql/conf.d
- /opt/mariadb:/var/lib/mysql
ports:
- 3306:3306
The config is as follows:
recorder:
purge_keep_days: 30
auto_purge: true
db_url: mysql://homeassistant:***@192.168.2.61:3306/ha_database?charset=utf8
However when restarting I get this error:
2022-05-23 23:52:41 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1044, "Access denied for user 'homeassistant'@'%' to database 'ha_database'")
I’ve already tried a lot of different test and combinations without any success.
Can anyone point me in the right direction?
I guess this has something to do with the docker container with mariadb, which doesn’t provide the correct rights to make this connection work.
Thanks for the help!
Pieter
