MariaDB Install and Setup Questions
I’m not an IT person and trying to fumble my way through the MariaDB install. For some reason can’t find any good videos on this.
My setup is I use Proxmox on a NUC with HA setup as a VM.
I’m following these instructions but am stuck on how to create a mariaDB login and user. I’m sure this is simple for IT folks, but not for me. Does anyone know the easy way to do this?
Also, if I need to type commands please let me know if I do that on my proxmox server or the HA VM?
If there’s any other steps you think I missed please let me know. Sorry for the noob questions.
Mark
I was able to get the user and db created but this was on the Proxmox server and not in the HA VM. Not sure if this is correct or not. I added this to my configurations.yaml file:
recorder:
db_url: mysql://homeassistant:password@core-mariadb/homeassistant?charset=utf8
My MariaDB database and user are both called homeassistant.
I get these errors in the logs when I restart HA:
2021-01-10 13:06:23 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
(Background on this error at: http://sqlalche.me/e/13/e3q8) (retrying in 3 seconds)
2021-01-10 13:06:26 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
2021-01-10 13:06:29 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
2021-01-10 13:06:32 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
2021-01-10 13:06:33 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2021-01-10 13:06:35 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
2021-01-10 13:06:38 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
2021-01-10 13:06:41 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
2021-01-10 13:06:44 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
2021-01-10 13:06:47 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
2021-01-10 13:06:50 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1045, “Access denied for user ‘homeassistant’@‘172.30.32.1’ (using password: YES)”)
2021-01-10 13:06:50 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Integration failed to initialize.
2021-01-10 13:06:50 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: recorder
2021-01-10 13:06:50 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
2021-01-10 13:06:50 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: recorder
2021-01-10 13:06:50 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2021-01-10 13:06:55 ERROR (MainThread) [homeassistant.config_entries] Error unloading entry configuration.yaml for sensor
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 321, in async_unload
result = await component.async_unload_entry(hass, self) # type: ignore
File “/usr/src/homeassistant/homeassistant/components/sensor/init.py”, line 72, in async_unload_entry
return await hass.data[DOMAIN].async_unload_entry(entry)
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 172, in async_unload_entry
raise ValueError(“Config entry was never loaded!”)
ValueError: Config entry was never loaded!
2021-01-10 13:06:56 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: history, logbook
2021-01-10 13:06:56 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2021-01-10 13:07:06 WARNING (MainThread) [homeassistant.components.netatmo] Webhook not registered - https and port 443 is required to register the webhook
Any ideas what I did wrong in setup?
Did you find a solution? facing the same problem …
SpeedMaxX,
No i have not. I abandoned this effort and will at some point uninstall and try to reinstall MariaDB and hopefully get it working.
Finals solved it by setting a new password without some special characters
