So I have been having some issues with my home assistant which I have eventually realised is because of the hass.io mariadb addon.
The first thing I have been seeing is that I have a package with themes.yaml in it with around 30+ themes in it. WHen 0.99.0 was released, I edited this file to add some extra variables so that the unused devices screen would display correctly. As soon as I did that, I started getting a database error when I restarted HA with it having a problem writing the theme to the database. I found that it was ok depending on how many of the themes I edited with the variable. Odd.
Yesterday, I decided to use a themes directory and split up the package so every theme was in it’s own package and I again edited all those themes for the new variables. The dB error returned when I did that.
In addition to this, regularly during the day, my home assistant was becoming unresponsive for a minute or so at a time. It always came back but it was happening all the time. Very annoying.
Lastly, a lot of my history graphs were flatlining after a day or so. I have recorder setup to not record 90% of entities etc so this was also odd.
Anyway, seeing the database errors yesterday I decided to switch back to SQLite dB - the HA default. As soon as I commented that out, all the above errors went away.
Has anyone else here had problems with the mariadb addon? I guess I can re-enable it and get the logged errors (and log an issue on github) but curious if it’s just me or not?
